Hi folks.
I cannot export correctly a scene as a 2D jpg. A large text object is shown as a large dark gray rectangle in the jpg file. All other text objects are correctly exported.
If I export as pdf it works OK.
I have no explanation for that.
Here is the file.
Tandem test.skp (131.0 KB)
And the result of jpg export.
What export option settings did you use for the jpg? I found that having anti-aliasing on causes this effect unless I increase the output pixel count.
Screen texts are odd beasts. They don’t involve any geometry, they are just dynamically drawn to the screen via OpenGL primitives.
I was using a resolution of 3258 x 1818 for export.
Anti Aliasing was ON and that was the problem.
After turning off AA, everything is OK.
Thank you very much.
