Hi. I made a key chain. Basically just a name and square going through it. Is there away , a script or something to create a template where i can just change the name?[Processing: IMG-20220915-WA0073.jpeg…]
Thanks
Thanks
At least for the 3D text you can use this:
3D Text Editor | SketchUp Extension Warehouse
(you need to install this too: TT_Lib² | SketchUp Extension Warehouse )
Then resize the square rod after you edited the text componets
Thank you.ill check it out…i think 5he square might become a problem
Why is that?
I have no idea what that could mean. But if you say so, there will be a problem for sure. ![]()
Since the word will be longer or shorter so you will have to adjust the square manually.
not a biggy but was hoping theres away i can do a script like in afterfx and so on
Hi. I installed them but not sure where to access them. it still uses the standard 3d text box
I don’t know how in “afterfx and so on” goes, but certainly in Sketchup you can do a script. You just need to learn
https://developer.sketchup.com/developers/welcome
You need to restart Sketchup after installed 3D Text Editor Extensions (and TT Lib), then:
Menus
Can you please tell me what is that mean?
Should only take a few seconds to do.
Bud you are awesome. Thanks
