Thanks. To be usable and nimble in SU, I will have to swap out much of the SU structure with something a bit simpler and cleaner. The last step is to figure out the logic behind the piston jacks. It shouldn’t be to difficult. I will update here when I get it finished.
I am pretty much done. I decided to remove the model’s lift cylinders and replaced them with cylinder nodes from Trimble Creator. I couldn’t get the correct angles to work and in using the cylinder node, I was able to simplify much of the logic without sacrificing to much detail.
I also added functionality to the outrigger arms and feet.
That is cool. I’m not familiar with creator. Is that something I have access to as part of SketchUp pro? Any chance of a youtube video of how you accomplished this? It is something I would definitely learn how to do.
