Tape Measure resize - error
Hello, I’m trying to rescale site survey DWG with Tape Measure tool. I get the message ‘Note that components within the model that were loaded from external files will not be resized!’
647601 Layout1.dwg (4.5 MB)
I’ve tried Exploding file but it crashes my machine. Any ideas?
I’m using Macbook Pro 2019
Did you try opening the component for editing before doing the resize?
Brilliant! Thanks Dave that worked.
Did you try selecting the correct import unit when importing the DWG? (options button in the import file dialog box). It should be set to the same unit that the DWG was created with.
