Model is not changing dimensions
Good morning,
Using the measuring tape tool to adjust the scale of my model is unoperative.
I know for sure that the edge I’ve highlighted in the below image is 168.267m.
Any assistance would be greatly appreciated, thank you.
WBP CAD Master Plan V13.skp (172.5 KB)
When you attempt the rescaling, the dialog will tell you that components imported from another file cannot be scaled. That’s the problem here, as the entire model is an imported component. Select and explode the component and then scaling with the tape measure will work.
