Is there an actual reason for it?
I am trying to keep my Toolbar “clean” and organized but as the Tags line is becoming this long, it shifts my extensions out of sight beyond the screen.
Just wondering if this is deliberate or a bug.
Joth
I think it is probably a “feature”. The tags toolbar uses a drop-down selection, which perhaps can’t be programmed to change width on the fly, so is expanded to be able to show the longest name in the list.
BTW, I just tested it. If you give a long tag name, the Toolbar size will not change in the current session. Only get longer if you open it by double click on a file.
However if you are opening first the default template, then opening your file with long tag name from Menu File>Open (or recent), the Tag toolbar won’t get longer. So that one a 6th workaround…
