Tag override
Hello, i was excited to learn about the tag override setting in layout and thought that this would be a way to avoid stacking viewports to control line weights.
I think I have this setup according to the YouTub vidoes… I have a scene, there are object on maybe 4 tags displayed. I have a viewport in layout. i’m rendering in vector. But when i change properties of the tags, nothing happens.
When i change to raster, one of the lines (but only one), showed in the color i chose in the override. But otherwise, it all the other lines showed black.
Am i missing a step?
tks
Post your LO file (drag it to the reply window) so we can see how you have it setup.
If it is too large you’ll need to use DropBox or WeTransfer or similar and share a link.
sketch_test.layout (1.7 MB)
As I test this, it appears to be something to do with the Section I have? It works for objects that are not cut by a section, but no the ones that are cut by a section. Is that a limitation of this feature?
Section Cut lines are their own thing and are not linked to the tag that the object that is being cut is on.
OK. Thanks. Disappointing. An almost good feature. No option but to continue to stack viewports
