Hello.
I am trying to figure out what is going on with Tags in my project.
I have the six-sided shape assigned to Untagged.
I have the small rectangular shape assigned to the 002_top_panel tag.
I have the larger rectangular shape assigned to the 001_base tag.
All of these objects are a Group.
The eye (hide-unhide) option works for both the Untagged object and the 002_top_panel object.
Those objects hide (disappear) when I click the eye icon.
But, clicking on the eye icon for the 001_base tag in the Tags menu doesn’t do anything.
And, there isn’t an “X” for that tag. I tried I deleting the larger rectangular object thinking the delete tag function needed to be not assigned to any object.
Nor does the “Purge Unused” icon delete the 001_base tag if I reassign the larger rectangular object with a different tag. So, it seems like I am stuck with this tag.
Clicking on the eye icon in the Entity Info section does hide the larger rectangular object. But, then I have to go to the Display menu (eyeglasses) to Unhide All to see the larger rectangular object again because the Entity section closes when I click the eye icon.
Am I interpreting how tags work in this example? I watched the Help video. I think I am doing it correctly. The category for this forum said that there might be bugs in the online/web version.
If I am using the tags correctly, then is there something wrong with the 001_base tag?
The larger rectangular object is not locked as you can see from the screenshot.
I can try suggestions and attach more screenshots if necessary.
If this is a bug, where can I report it?
