Howdy,
Can I just check if this tagging behaviour is normal? I’m not sure if I’m misunderstanding something or experiencing bugs.
The first is I have an entity which belongs to tag ‘02 upstairs’. When I hide things with tag ‘01 ground’ it hides this entity which is not what I was expecting. I mean, this might make sense if the multiple tags could be assigned but that seems quite inconsistent with teh UI and the impression I got was entities have one-or-none tag.
The second is when I go to set a tag to active it changes the alphabetic ordering of all my tags.I was thinking these behaviours should be largely orthogonal, but again not sure if I’m misunderstanding.
I guess a couple of ‘rider’ questions is:
is there a way to change the order of tags? I couldn’t figure out how to so was hoping to rely on prefixing with numbers to provide order, but that doesn’t work well with the behaviour above, perhaps there is a better way to do this?
Is there an established/recommended way of searching the documentation for sketchup for web? The documentation for this seems to be markedly different for the non-web versions (admittedly I’ve never tried them). Everytime I google or search the forums I get a lot of things that are not relevant to me (even with the forum-tag filtering). No worries if this is just a pain point that has to be endured but as before, if I’m missing something obvious, it would be good to know.
Thanks!
