Could you share the file you created in AutoCAD? It would be easier to help you than looking at that screen shot.
Keep in mind, if you do extrude that whole surface, you will create a large number of entities which will bloat the file. It might make more sense to use a texture or create a small section as a component that you can copy to fill the space.
If you use the CAD file, you’ll need to create a large face to put the lines on. An easy way to create all of the openings is to select the face you want to keep by double clicking with the Select tool. This will select the faces and the bounding edges. Hit Edit>Copy to copy it to the clipboard. Then delete all of the geometry of the grid. Next, hit Edit>Paste in Place.
I had a question about this, @DaveR. I’ve read in numerous places that using Components instead of actually copying the geometries is better. Could you explain why, please? I experimented with this a bit but when a component is copied, the polygon count is doubled as well, so I don’t get how it keeps the file lighter. Can there be any visible difference when using component instances vs simple copies?
The entity count does increase with additional copies of the component but the file size doesn’t increase as dramatically. Try this: Draw a cylinder and make it a component in a new SketchUp file. Save it. Note the file size. Make 100 copies of the component. Save the file again and note the file size. Explode all of the components and save it again. And again note the file size. Here’s what I get.
If it’s done correctly, the method I showed won’t look any different than the single large mass of geometry.
Another benefit of making a component of a small section and copying it as I showed is that you can quickly and easily make modification to the whole by editing one, simple component.
Ok, here’s what I got and my results are drastically different from yours. The difference of my 100 grouped and 100 component cylinder files is just 5KB while your difference is about 6 times smaller.
I used the default 24-sided circle for creating the cylinder.
What else is in your In Model components library? Are there materials in the In Model materials library? How many styles and what styles are they? How big is a blank SKP file? Just open a new one and save it.
Oops! I think I’m in trouble. No components, no materials, just one style used and a blank Sketchup file is 1.4 MB. I use a lot of plugins + rendering engine. Can that be an issue?
Here we go. Thanks for helping guys. @DaveR I forgot to mention that I also used 24 sided circles. @john_drivenupthewall Thanks for further explanations. I had to reread it a couple of times to understand but I think I get it.
I turned off Endpoints and updated the style (it was showing as modified when I opened it anyway) and that reduced the file size to 179Kb. Not sure why it’s still so large compared to mine.
I wouldn’t think they would add much to the file size but if I remember correctly, they are generated by a png file in much the same way sketchy line styles are made.
model = Sketchup.active_model
attrdicts = model.attribute_dictionaries
# Iterates through all dictionaries and prints name ans number of keys.
attrdicts.each { | dict | p [dict.name,dict.size] }
returns…
["GeoReference", 7]
["temp", 1]
["Something...Check the previous project to see the value we used", 2]
["GSU_ContributorsInfo", 2]
entering
attrdicts.to_a[2].to_a.flatten.join.size # this one is vRay
Carried around with every skp? Oh boy! Do you know if it’s a normal behaviour or I messed something up? By the way, thanks again for looking into this all you two!
