Hi. I am using SketchUp Pro 2021 on a macbook pro, and the push-pull tool won’t work when I tried to cut a hole on a rectangle to create a door frame.
I drew a rectangle with its base sitting along the X-axis and its height along the Z-axis (see below). I then created an offset, tried to cut a hole by using push-pull tool to remove the inner part, but it didn’t work. It only kept extending the inner part.
However, when I tried to create a door frame by first drawing from the bottom along X- and Y-axis, pulling up along the Z-axis, creating an offset, then using the push-pull tool to cut the hole, it works.
Does anyone know what is going on here and why is this happening? How can I resolve this matter?Thanks very much.
