Uninstalled and reinstalled as Administrator (including a required system restart)
After reinstall in shortcut preferences both Shift+Z and Ctrl+Shift+E are set for zoom/extents
Deleted Shift+Z and reassigned Ctrl+Shift+E to another action. Saved file and reopened and zoom/extents has reset itself to Ctrl+Shift+E but not Shift+Z
I have even edited the PrivatePreferences.json but it keeps on resetting
But can you assign that combo to another function?
I believe that was the OP’s original issue all about?
So, we have a bug or it is not suppose to change on Windows, as @slbaumgartner suggested.
While I have a model open I can set ctrl+shift+E to perform another action and it will work performing that action until I close the model. On reopening the model something had reset ctrl+shift+E back to zoom/extents
It is not ‘model’ related, but ‘SketchUp session’ related, I presume?
Exact steps are important.
Do you open the model by double clicking on it in the explorer, change the shortcut, something else in the model and then exiting through the file menu or by clicking the window ‘away’ (x)
Until this post I have, for years (under previous versions of SU and the current 2019.2 update), successfully been able to assign ctrl+o to another action without SU resetting it to the default open file dialog.
With all my recent uninstalling and reinstalling of SU I find that ctrl-o is being reset to the default action
With windows the all the 2019 shortcuts are not in the preferences file. It appears that some of them are hard wired in the program. The shortcut for zoom extents is not listed in the file and can not be changed in the preferences window. This is something that has been bugging me also.
