SU GIF Exporter - Make animated GIFs in SketchUp
I love 3D models (like many people here, I’m sure). Unfortunately, they’re still not as ubiquitous as images, so sharing them widely remains a challenge.
But flat screenshots of 3D models can be frustrating. I can’t help but want to rotate the object and see the dark side of the moon! :slight_smile:. I think animated GIFs are a good compromise. So, until native support for 3D models becomes the norm, I thought an extension that generates them directly from SketchUp might be handy.
Introducing SU GIF Exporter:
Features
  • Preview: Displays a preview of the generated GIF.
  • Settings:
    • Resolution: Adjust the width and height (in pixels) of the output GIF (default: 640 x 480; max value: 16000 x 16000)
    • Speed (Degrees per Frame): Rotation angle (in degrees) of the model or camera per frame.
      • Predefined options: Slow (5°), Medium (10°), Fast (30°).
      • Custom: Enter a specific rotation step (in degrees).
    • Delay: Adjust the delay (duration in milliseconds) between frames (default: 300 ms).
    • Rotation:
      • Origin: Apply the rotation either to the model’s center or the camera.
      • Axis: Set one of the default axis X, Y, or Z as the rotation axis (default: Z).
      • Direction: Define the Clockwise (CW) or Counterclockwise (CCW) orientation of the rotation.
  • Export:
    • Generate: Begins the GIF creation process with the configured settings.
    • Save: Saves the generated GIF to a local file.
How to Use
  1. Configure Settings: Set the desired resolution, speed, delay, rotation axis, origin, and direction. If “Custom Speed” is selected, specify the step angle in degrees.
  2. Generate GIF: Click “Generate” to start the GIF creation process. Monitor the progress bar and preview window.
  3. Preview: Click the “Preview” button to pause/play the resulting GIF after generating.
  4. Save GIF: Once the GIF is generated, click “Save” to download it to your device.
Examples
Exterior view with model rotation (loops forever)
exterior_model_rotation
Interior view with camera rotation (loops 2 times):
interior_cam_rotation
Miscs
  • 7-Days trial - full access
  • Permanent licence for $25 USD
  • Get 20% OFF if you purchase before end of trial
  • Video export very likely to be added in the future
  • Submission to the Extension Warehouse coming soon.
Please have a try and let me know if you like it (or not :stuck_out_tongue:).
A quick case study regarding the importance of the model selection when the Origin option is set to Model (which means that the rotation is applied to the model):
Although the slab in the below image is hidden, it still affects the selection leading to an unbalanced box…
And thereby unexpected rotation as illustrated below.
unbalanced_rotation
A quick fix is either to select individual components of interest (can be tedious), or just like I did here, delete the “noisy” components (just for the time of the GIF generation and restore if needed).
better_balanced_rotation
