Styles Tab on Layout 27
I’m working with LayOut 27, and in the Styles section of the SketchUp Model tray, I can see the “In Model” styles, but when I click into “Styles” the folders for the standard styles (Default Styles, Photo Modeling, Sketchy Edges, etc.). I think that previously I could get to these ‘built in’ style folders from SketchUp Model tray, but just seeing a blank box now. Am I doing something wrong, or is this a bug/feature in the new version?
I generally use this when I need a viewport to be wireframe or something that I rarely save as a style in the SketchUp modeling process- popping back and forth to SketchUp to quick record a new style into the document seems like a tedious step that I didn’t have to do before.
Thanks in advance
Mac M3 15.8.3 / LayOut 27 / SketchUp 27
follow-up, as I explore some more- In SketchUp, when I click the file Style folder in Preferences>Files I get an empty Finder folder window- is that normal? (I checked for hidden files and folders as well- nothing there). The Styles tray in SketchUp is working fine, and as expected, so SketchUp is able to find those styles somewhere.
I’m a little baffled.
Thanks
That empty folder is normal, so it is probably not the cause of the blank list. The Styles folder shown in Preferences > Files only holds styles you add yourself. The built in styles ship with the application, which is why SketchUp still finds them even though that folder is empty.
Does the list stay blank in a brand new LayOut file with a fresh viewport too? If it does, that points to LayOut rather than anything in your model, and it would be worth reporting as a LayOut 27 problem with the version details you gave.
Thanks for checking in on that Styles Folder. Yes, this is consistent with a new document, and the import method (Send to Layout from SketchUp, and Insert in Layout).
My new hypothesis is that it’s a read permission thing somewhere on my mac, because now 26 is doing it too.
Trying a reinstall, but now Mac is ‘unable to verify that it isn’t malware’ and won’t open SketchUp or Layout at all. I’m going to put it away and wait until Monday.
Are you even using LayOut?
