I would like to import an .stl file that was created using Catia V5 (I don’t have that software) using Google Sketchup Pro (Version: 19.2.222). When I’m trying to import the .stl-file, sketchup totally messes up the object, as follows:
Thank you so much Box and MikeWayzovski, now, everybody know how to draw a circle, thank you for your time and effort, but the question is that there were (and there is) a problem importing STL files created by Catia.
Thanks for the “constructive” comment. Neither the six year old topic starter nor you provided any meaningful information. So, Box and Jack gave the best answer possible based on that.
If you share your problem in detail and give examples (stl file), we have a better chance of helping you if you want to, unless you’re just here to rant or blame.
Simple thing to model, I probably would have modeled it from scratch in SU in about the same amount of time and I’d have a cleaner, smoother object when finished.
I wonder what it is about that .stl file that causes the issue, though.
Interesting. I wonder why we got different results
Even after merging coplanar faces there seems to be a fair amount of what should be unneeded triangulation. Out of curiosity I just modeled it from scratch and there’s no triangulation at all.
Ansii was close on the number formatting. Opening the file in a text editor and replacing every occurence of two spaces with a single space seems to be the ticket
The BUG is:
If a floating point number doesn’t start with a + or a - sign, the importer is interpreting the first of two sequential spaces as a ‘funky’ number. For example the line
