today I installed SkethUp Make with the PlugIn SkethUp STL.
The import function of stl files is in the import section available but the programm is hanging - nothing happens.
Only the “clock” (blue rotating circle) I can see, but after 20 Minutes I close the programm.
Has anybodey an idea what I can do to open the file?
Depending on what created it, an stl file can contain a vast amount of geometry. How large is the file you are importing? It takes SketchUp a considerable amount of time to import a file with hundreds of thousands of facets or more. 20 mins isn’t out of reason.
I wish stl would be standard for this program, I am having some odd issues as well. Cannot load many stl files. it keeps trying to clean them up or some dumb thing.
If .stl files do not work, this software is useless for me and 3D printing
I had to scale it by 1000 on import as it a very dense mesh, but i came in ok…
if imported in inch or mm these sizes will cause issues…
============== Size ==============
Min X = -7.154811, Max X = 7.154000
Min Y = -6.734457, Max Y = 243.369781
Min Z = -18.930080, Max Z = -4.617066
========= Facet Status ========== Original ============ Final ====
Number of facets : 201089 201090
Facets with 1 disconnected edge : 3 0
Facets with 2 disconnected edges : 0 0
Facets with 3 disconnected edges : 0 0
Total disconnected facets : 3 0
=== Processing Statistics === ===== Other Statistics =====
Number of parts : 1 Volume : 8907.813477
It has some errors on the base preventing it being a solid…
I ran it through admesh which added one edge. [took 10 seconds]
