I have an STL file that immediately fails to import. I have tried changing to meters as well as merging coplanar faces. Any other ideas?
Share the .stl file so we can see what you are working with.
2025 HD Expo Final Part.STL (1.5 MB)
It seems the .stl is corrupted. Where did it come from? What software was used to create it?
Thank you for checking. I was able to open it here. Would it still open here if corrupted? Free online STL viewer!
possibly.
sketchup only has an importer, so any issue with the structure of the file might result in a failure.
a dedicated tool like you used can have different processes to read the stl.
it opens in meshlab (a free software, quite useful)
from there I exported as a collada. and it imports fine in SU.
youâll have to adjust the scale though, because I didnât ![]()
here is the collada file to import
2025 HD Expo Final Part.dae (264.8 KB)
meshlab. I still havenât learned to properly use it, but I often use it as a simple viewer, or to do what I just did ![]()
so helpful, thank you
This topic was automatically closed after 186 days. New replies are no longer allowed.
