While running Sketchup 8, I cannot import or export a .STL file without errors. I do not know if it’s the export process because I have no other way of opening the file. The extension I am using is Sketchup SLT import/export from the extension warehouse. Does anyone have a work-around for this issue?
Here is my original drawing: CogII.skp (1.4 MB)
And here is the converted file:
The site will not allow me to upload the .STL file, so here is a picture:
What are the errors you experience? And at what point in your process do you get the error?
Which release of SketchUp 8 do you have? And what version of the STL extension are you using? (Can you also verify you are using the Import/Export extension from SketchUp and not any of the older variants?)
Can you upload the STL to Dropbox or Google drive or anything?
Oops, I neglected to add STL as an acceptable file type so I just fixed that. I even added .GCODE for fun as well.
From the screenshot you included @brainfarth I don’t think you’re seeing an error specifically, rather there is just a lot of junk in there and SketchUp is having a hard time calculating faces. I’ve run into this many times on an STL import and the sad truth is that sometimes you’ve got to spend time cleaning up if you intend to modify the STL much before printing.
Beyond that, @tt_su is a great resource to leverage when it comes to your importing as he’s got a handful of great Extensions that might simplify your workflow.
The error as I see it is after I export the gear as a STL file and try to re-open that STL file, it’s scale has been reduced to about 1/28th of it’s original size. Also, there are lots of new lines on the model.
This is the extension that I have installed: Extension | SketchUp Extension Warehouse
I thought that maybe it was only that file, but all of my attempts are the same result.
STL doesn’t contain any unit information. So applications have no way of knowing if an STL is in mm, cm, m or inches.
With the STL exporter you can specify which unit you want to export it to. I think it defaults to the current model units.
When you import you must set the appropriate unit for the file you open. (Not easy if you don’t know what unit it was exported in.)
The STL format stores the geometry in a triangulated mesh. Any face in SketchUp that isn’t a triangle will become triangulated as you see in your screenshot. There is an option upon import to erase edges between coplanar faces that will clean it up.
Yea, it’s easy to miss. It would have been much easier if the STL format had a way to define what unit it used. Then manually setting it wouldn’t be needed and we’d avoid this hit and miss. Alas…
Hi, it happens something similar to me. Before, I could export to STL files without any problem, but whe I updated the extension It started not to work. I’m using Sketchup Pro 2013 and everything works fine except this extension. When I click export and ok it does anything (after disappearing the location selection box), and no file is saved. Sketchup does’t appear to have any bug and it continues working as normal.
Here yo can see what the Ruby Console writes:
I was specifically referring to SketchUp’s STL plugin, and Thomas’ comment of how the unit needs to be set manually while importing.
I don’t think other apps would care if the was a unit substring in the middle of a filename. They’d just ignore it.
But the SketchUp STL importer could “notice it” just before the extension. So to that end the plugin also writes STL files, so it could also insert these substrings into the filenames (according to a plugin option, if you wish.)
The plugin could also support the “Netfabb” convention, at the same time.
