I received an SketchUp model from my daughter. We have the very same version, but I can’t open the file, (It´s a 100 MB file). but when I try to open it, there’s nothing in the template, only the green surface with the 3D lines. Has someone had this issue? Thanks for your help! Best regards!
Thanks Julian,
Both W10, but her machine is newer than mine. I couldn’t say exactly her PC specifications, due to she is in America and I’m in Europe, so, she’s not available riht now.
Thanks a lot for your help and pretty valious time! I just downloaded the file again, rename it and finally, the model came up! So my issue was solved.
Excellent! Strange that a damaged file would still open in SU.
If you are going to be using SketchUp more often, and depending on how you value your time, you might want to look into upgrading your system specifications.
