Hi there,
I installed the French Windows version of SU 2019, then decided to update an existing manual in English for version 2016. So, I removed SU 2019 Fr and installed SU 2019 En.
Surprize surprize, there is some French stuff left:
Classic License:
Remove license, first ([menu]Help->Welcome to SketchUp and then click the remove license button in the classic license tab
Then run the installer and choose Remove
Subscription:
Log out, first, then run the installer and choose Uninstall
both by rightclicking on the installer fiel and choose: ‘Run as Administrator’
Then install the version of you liking (rightclick etc.)
There is some sort of hack that let’s you run both domestic and english version, you need to install the domestic language and run the english version by adding a parameter behind the exe- command.
lang_dirs = Dir.glob('/Applications/SketchUp 2019/SketchUp.app/Contents/**/fr')
lang.dirs.each do |dir|
File.rename(dir, dir + '_non')
end
## to restore
lang_dirs = Dir.glob('/Applications/SketchUp 2019/SketchUp.app/Contents/**/fr_non')
lang_dirs.each do |dir|
File.rename(dir, dir.sub(/_non/, ''))
end
I removed the sw then deleted the two appdata hidden folders (in Local and in Roaming), then reinstalled the sw and now I do have “Default Tray” instead of “Palette par défaut”.
Topic closed for me.
Thanks to all.
