Unable to change language back to english of Sketchup Pro 2018
For some reason my Sketchup 2018 pro changed the language from english to swedish. I can’t get the english version back for the program.
This is so frustrating. I have set locattion to US and windows display language to English. Downloaded and installed the english version of SU over the old version but still it’s in swedish. How could I revert to English and have it stay that way.
This is so frustrating!!!
SketchUp includes two languages: 1. the localized language which is loaded if it matches the system language, and 2. English (en-US) as fallback which is loaded if the system is set for example to another language (e.g. Swedish SketchUp on Portuguese OS). As far as I understand, after restarting Windows, the system language was loaded as English (en, en-GB or en-US), and so should SketchUp load English. I doubt SketchUp requires the OS to be set to US English, since there are British users (who have to cope with American English due to lack of translators).
You could:
  • Uninstall the Swedish version of SketchUp Pro and only install the English version.
  • You could edit the shortcut that launches SketchUp (right-click shortcut → Properties → target → append -lang=en-US after the executable path)
Hello @stefan1
In searching the Help articles, this is all I find regarding language settings in SketchUp.
Changing SketchUp’s Language — SketchUp Help
Yes I found that as well. But my windows display language is not Swedish, yet I’m not able to use Sketchup in anything but Swedish. Also there is a problem with all of my keyboard shortcuts.
All keyboard shortcuts are gone, but if I try to reassign them I get this message to reassign to the same thing…
one thing that comes in mind is the way you installed the English version.
I had a simular problem when installing a french version for testing purposes. Educational institute would like to give their students a choise: French or English.
The only thing that worked was:
To uninstall the priorly installed version (in my case EN, in your case Swedish): right click on the installer file and choose ‘Run as Administrator’, when prompted, choose ’ Uninstall’
Then run the installer file of the version that you would like (Rightclick, choose ‘Run as Administrator’)
In my case,I installed a French version and added -lang fr to the shortcut as @Aerilius explained.
I now have two shortcuts on my machine and can run both versions simultanously:
Where exactly should this -lang=en-US be typed ? Tried many spots. Got invalids.
Ex:
“C:\Program Files\SketchUp\SketchUp 2020\SketchUp.exe -lang=en-US”
Append after the file path, not in the file path.
If path is in quotes (e.g. because path has spaces), then try:
"C:\Program Files\SketchUp\SketchUp 2020\SketchUp.exe" -lang=en-US
