From English version to French version
If I uninstall my English version of SketchUp Pro to replace by a French version, will it be ok with the license? I am afraid that when I download the French version, it won’t reconize my license. Thanks!
Should be fine, but you can only Have one version installed at a time.
The bigger problem is that you only get French if your OS is in French. You can’t show French menus with the French version, on an English OS.
You would get the French version from this page:
Thanks, I will try!
Even if SketchUp is stupid in regard to languages, you can force it to use a desired language by adding a parameter to the shortcut’s target. Doesn’t work though when starting SketchUp by double clicking an .skp file.
