I’m trying to model a 3D form based on this odd shaped plan and the almost rectangular (there is 3 deg slope on the top edge) profile. I will need to repeat this process on multiple unique forms so I thought I’d see if anyone would be willing to check my process. I do prefer a solid form and with minimal edges visible in an elevation view. So for example the vertical edges closing the top plane to the bottom plane along curved edges - it would be nice to perhaps have a single edge that defines the change from a smaller radius curve to the larger radius curve. I do realise that because of the height of the front curved edge varies, that this might be difficult to achieve.
I used “push pull” on both planes and then the “intersect faces” tool to intersect the two forms with each other. Afterwards I manually deleted unwanted edges and manually filled between the top plane and bottom plane to fill in the side faces.
Since you have pro I would use Solid tools. Here I have used split.
You also have one group nested so I exploded it first to get rid of the nesting, and welded the edges to stop the extra edges forming on the sides.
