Hi there,
I’m relatively new to SketchUp and struggling to understand how the Solid property works.
When I am creating a rectangle, puhpulling the rectangle, triple click and make a Group, then the group is a Solid. So far all good.
When I try to do the exact same thing not with a rectangle but with the profile of the room I’m trying to build, I can push pull, I can group, but it seems what I get is never “Solid”.
This is very annoying as I need to have it solid to use some solid tools (substract) for some special openings in my wall…
Can someone point me to directions how to fix?
(uploaded my files in case…)
Thanks to both of you @DaveR and @Box, am still very new and then discovered the Solid Inspector tool… and found those sloppy corners… no idea how this happened but I fixed it!
I have not upgraded yet, I am evaluating the difference between Pro and Make trying to do a few small things.
Then may be I’ll upgrade to design my new house interior very tempting but a bit of money for an individual…
Since you’re using a web based version according to your profile, you can’t use solid inspector, you should check if there are stray edges, hidden geometry or missing faces. If you share your file it would be easier to detect the problem.
