Hi,
I want to see every group solid or not . But also there is solid problem in model bu if I select all groups the solid inspector not showing any error.
Is there a solution?
Hi,
As your screenshot suggests, you can use the tab key to zoom to the error.
Copy the main group that includes all subgroups, explode all subgroups then run Solid Inspector… You will see all errors…
