I installed “Solid Inspector” plug in but do not know how to access it. I’m assuming there should be an icon for it but I don’t see it. Can you help?
thanks akomet
If you installed it correctly, you should find an entry for it in the Tools menu.
It’s clearly explained on the page for Solid Inspector.
It also needs TT’s Lib installing…
Did you do that ?
Also… with SketchUp v2016 there is a known glitch, which might mean that although it is written to load activated when it’s installed, it loads deactivated - so you need to activate its Extension [from Preferences] after it is first installed.
But thereafter it will remain activated when you start Sketchup…
Hopefully an upcoming maintenance release will fix that problem…
Although SolidInspector is menu driven [Tools menu item], its sibling - SoildInspector² - does also have a toolbar [once it’s activated as outlined above etc]…
