Soap skin & bubble extension--Timelimit finished
Hi
Im getting this error “timelimit finish”. Im using soap skin bubble extension
That’s not an error. For whatever reason the author made it time limited. Download and install a fresh copy of it.
just the new installation finish and used it and it work, ur answer pop-up :thumbsup:
How about marking my answer as the solution so others will know it is solved?
i did try uninstalling and installing it again on my PC but the problem still persists. what do i do?
I use sketchup 2015 pro.
Did you get a fresh copy of the extension from the Extension Warehouse? It says there that the extension expires April 2018.
HI,. it-s me Karin…i´ve got the same problem with: timeline is finished…and it will not intall teh soap skin & bubbles, as it there is a warning, saying: not signed!
How can i get to this wonderful plug in?
cheers, Karin
Although it is not signed, SSB should work as long as you have the current version installed.
Even though I have reïnstalled the plugin, by downloading a new copy, placing it in the sketchup folder (removing the old copy) and installing it when in Sketchup, I still get the ‘Timelimit’ warning.
Does anyone knows what I am doing wrong?
