Seeking advice on the best-easiest method to increase the size of a complex model at a slice plane somewhere in the ‘middle’ of the model, as opposed to Push/Pull/Move at one ‘end’ of the model.
In my case the model consists of a house design consisting of a complex hierarchy and organization of groups and components – e.g., foundation, exterior walls, interior walls, windows doors, … and much more. I need to increase the size of the building, increase the square footage. I could do this manually by Pulling and Moving out the various and numerous entities at one end of the building, and manually shifting over and fixing all the numerous interior objects.
A simplified example: A house box consisting of exterior walls, interior walls, windows, and a roof; each in their own group. Now I want to make this bigger. I can do this by Pulling out a exterior wall; Pushing out the interior side of the exterior wall; move all the windows out that are on that exterior wall; do the same with the roof; and then Pull to extend the interior walls that touch that end of the building. But it could save a lot of time if I could create a slice at a strategic location through the model, if there was a (semi-)automatic way the model could be extended at that slice – e.g., the walls automatically pushed out, and windows moved out.
Or am I stuck doing it manually? Thanks.
