Skyscraper Design
You can make some cool building shapes by dividing organic forms into floors.
Have you tried the Slicer5 (TIG) extension?
I briefly tried it out, but couldn’t get it to work. It said the thickness can’t be greater than the spacing. I wanted 10’ slices with 0" spacing, so I’m not sure if it would work for this. It would be a great time saver if I could figure it out though! I manually push/pulled each slice because joint push/pull was having errors with it.
The Slicer5 interface can be a little unclear - I have only used it on 1 terrain where I made the thickness the same size as the slices - it worked fine.
Cool! I got my inspiration for the skyscraper from a dream, except there was a futuristic city in the background and an oranger sunset. I woke up and had to model it.
These towers often catch a brilliant orange sunset light.
