I had an iMac 2012, and SketchUp would not quit. Whether I used the pull down menu SketchUp > Quit SketchUp, or just hit Command Q, it would not quit and would just hang there until I used Force Quit.
I’ve now got a new iMac 2017 running Catalina, and the same thing happens almost all the time - I started a new file today using the imperial template (which I never use). I didn’t do any work, I just opened it then hit Command Q and it worked. So it must be a problem in the files I’m using…?
Any ideas anyone?
thanks in advance
Sorry… your profile still says 2018. I would recommend turning all your extensions off and see if you have the same issue. Every time I have heard this, it ended up being an issue with extensions.
