SketchUp won't launch normally but works from Terminal
Hi all,
Running into a weird one here. SketchUp (2024/2025/2026) hangs when double-clicked, no window appears and I have to force quit. But if I launch it from Terminal it works fine:
/Applications/SketchUp\ 2026/SketchUp.app/Contents/MacOS/SketchUp
Console output shows:
objc[18557]: Class SKTextPath is implemented in both /Applications/SketchUp 2026/SketchUp.app/Contents/Frameworks/SketchUpAPI.framework/Versions/A/SketchUpAPI and /Applications/SketchUp 2026/SketchUp.app/Contents/MacOS/SketchUp. This may cause spurious casting failures and mysterious crashes.
2025-11-10 12:12:40.195 SketchUp[18557:292919] BugSplat start...
2025-11-10 12:12:42.944 SketchUp[18557:292919] [HockeySDK] WARNING: Another exception handler was added.
Environment:
  • Apple Silicon M1, M2, and M4 Macs
  • macOS Sequoia, Tahoe (latest versions)
  • Managed via MDM, Huntress antivirus, and Level.io RMM
Same setup in a VM works perfectly, same console warnings but app launches normally via double-click.
Anyone seen this before?
Thanks!
