Hi All
I hope someone can help me with this.
When I draw an object i.e. a rectangle, the measuring and line tool won’t snap to the outline, in fact there is no outline shown. If i a new file and it works fine and also works fine in older generated files so I am thinking it is something wrong with this particular file.
Regards Ronan Keegan
Sounds like you have edges turned off in the style. Turn them on and you should be in good shape. If that’s the fix, make sure you update the style afterward.
Which version of SketchUp Pro are you using?
Cheers Dave
That worked perfectly.
My collegue has just told me he turned them off yesterday.
You’re a star!
Glad that helped and thank you for the compliment.
Ah… One of the joys of working on someone else’s models.
