I first load Fredo6 1001Bitstools and used it with success.
After loading the extentions SketchedUcation, I loaded the extention:
- deBabelizer
- SedusSketch
- Fredo6 LIB Fredo6
- StairMaker
- TNT_Checkchange
- 2d Tools
- bim-tools
- Fredo6 jointpushpull
- Section Cut Face
I went out of Sketchup and restart it.
Since then, I cannot draw anything in Sketchup anymore !
I tried to desactivate all new extention, but Stairmaker and deBabelizer cannot be deactivated
So now my Sketchup 2016 cannot be used anymore !
Thanks for your help.
Christian
locate your Plugin folder and rename it, i.e. Plugins!…
when you start SU it will make a new one with only the SU supplied plugins…
if SU runs you can then add the others one at a time to find the one that breaks SU…
bim-tools is very experimental and may be the culprit…
john
Hi John
Thanks for the hint. I just tried it.
When I started Sketchup 2016, effectively alle the Plugin added disappeared.
Unfortunately, when I tried draw Something with SU, there still Nothing appearing on the screen. (Ex. Rectangle or other).
When I used the projet I was working on, Nothing shows on the screen.
Christian
do you have Edges Hidden in the view menu or the Style settings?
it happens…
john
I have the following sets in the view menu
→ Edge style → Edge
→ Edge style → Profiles
→ Face style → Shadowed with texture
So, no hidden stuff, according on what I can see.
Sorry, hier I made the mistake to load Sketchup in French. So, I hope my translation are exact.
Christian
Question: What would happen if I disinstall Sketchup and reinstall it ?
Could that solve the issue ?
Cheers
Christian
—> SOLVED !
A very good old trick from Windows old days worked.
… I just reboot.
Christian
