I have a small watercloset with a bulkhead.
When creating a section plane it simply wont cut through my walls until only after I have reached the bulkhead front. That should not happen. It should not cut only when I reached already more than 380 mm beyond the inside wall surface…
Any ideas of how they will fix this problem?
Here you can see the section plane created:
Here you can see i moved just before my walls begin. I should already be able to see through but i have a white area inside and see nothing.
This is then toggled fromt the other side. I should be able to see through but i cant.
Only after I completely move in front of my bulkhead then a cut gets created.
But I´m already almost half of my room and this way i can´t show more of the inside space.
