I am trying to export a pdf keeping the colours of the edges defined by the materials, but when I export it some of the lines come out black.
Most of my elements are components since they repeated all over my model. I have trying applying the colour to the inside and the outside of the components and also tried colouring the edges.
The first image is how it looks on the pdf and the other one on the model
I am exporting them from the main application File > Export > 2D Graphics > PDF
I need them as vector, because I will edit them in Illustrator afterwards
I’m not at my machine but I wonder what happens if you switch to color the edges by axis… do you still get black when objects touch?
Or what happens if you switch to color by tag?
Dave - I assume some of the parts in your model are solids and are actually joinery so this isn’t some z-fighting error or is it when 2 infinitely thin entities touch?
All of the parts in my model are solid components. I’m not sure if it’s z-fighting but when it occurs, there is a face passing behind the edge. The thing is it doesn’t happen everywhere.
