I have a SketchUp Pro 2020 Classic perpetual license. My serial number starts with V.
I recently moved to a new computer. Before formatting my old computer, I forgot to remove/deauthorize the Classic license.
I installed SketchUp Pro 2020 on my new Windows PC. My Trimble ID sign-in works normally, but when I go to Classic License → Add License, the button is active, yet clicking it produces no response at all. No Serial Number / Authorization Code input window appears.
I have already tried:
- Completely uninstalling and reinstalling SketchUp 2020
- Installing it on a different drive
- Using a mobile hotspot instead of my normal internet connection
- Clearing the WebCache
- Renaming login_session.dat and signing in again
The behavior is the same before and after signing in.
I still have my original Serial Number and Authorization Code.
Is there any way to reactivate or transfer my existing 2020 Classic license to my new computer?
I will provide the license information privately if necessary.
I have some information about your license, which I will message to you. Look for a message from me (it should show up if you click on your avatar in the top right corner).
Hello Colin,
I have the same problem with SketchUp Pro 2020 Classic, but on macOS.
I have my original Serial Number and Authorization Code. I moved the license to a new Mac because the old computer is no longer available. I removed the existing license from the new Mac, but when I click “Add License”, the license input form does not appear and the panel becomes blank.
Could you please check my license and advise how I can activate it on this new Mac?
I have the same problem. When i open sketchup 2020, i can loggin, it say my account is active but i won’t load the sketchup, it keeps in the welcome screen, if i go to classic license it’s all blank, no buttons or anything, if i turn off my internet them the classic license show a message that i’m offline but shows up an activation button asking for my license, i put my license code it keeps saying its invalid.
Same issue. Have a 2020 Classic Licence, installed SketchUp 2020-2 on new M5 Mac and the classic licence sign in screen is blank @colin Can you help please?
Unsupported or not, why they just can’t have simple activation it stinks of trying to cut people off to force upgrade. I appreciate @ateliernab for letting me know
i compared the liclog on trial and activated license system.
Its server sided. mean they shut down the activation server or the activation server is offline.
I have the same problem with a SketchUp Pro 2020 Classic (perpetual) license on Windows 11.
After signing in with my Trimble ID, the Classic tab sometimes shows “No classic license found” with an “Add License…” button, but when I click it the panel turns completely blank and no Serial Number / Authorization Code fields appear.
I have already tried running as administrator, clearing the WebCache folder, compatibility mode, and an activation_info.txt file in the SketchUp 2020 folder. Nothing changed. Official support told me 2020 is outside maintenance and support, so I’m asking here.
Could you please check my license and advise how I can activate it on this computer? I can send the license details by private message.
I have the same problem with a SketchUp Pro 2020 Classic (perpetual) license on Windows.
After signing in with my Trimble ID, the Classic tab shows “No classic license found” with an “Add License…” button, but when I click it, the panel turns completely blank and no Serial Number / Authorization Code fields appear.
I originally purchased this perpetual license through an authorized reseller in Japan (Alphacox). I contacted their support, but they told me they are unable to assist with classic license activations because version 2020 is outside official maintenance and support, which is why I am reaching out to you here.
Could you please check my license details and advise how I can activate it on this computer? I can send my serial number and registered info via private message.
I can’t find a license for the email address you use in the forum. You can send a message to me to tell me the license details, so I can look to see if I can do anything to help.
Hello, I’m having the same issue. There is nowhere to enter the license information. I also own a perpetual license, and the software is completely unusable now
Please send me a message with your license details. I can’t find a license for the email address that you use in the forum. Click on my avatar to send a message to me.
Just wanted to post a quick update here as well. With your help, I was able to activate SketchUp Pro 2021 and get my setup completely back up and running.
