We are a high school and have Sketchup pro running on mutiple computers. A new class set of notebooks had sketchup pro installed and the activation_info.txt copied to the programdata location as per other installs.
I did not run sketchup on all the notebooks and it had not been used by students for some time and now the trial is expired and sketchup is not loading.
Run sketchup and its listed in taskmanger with high constant 20% + CPU usage but nothing loads on screen.
The EW.lic and Sketchup.Lic files are created and completely blank
RLM Diagnostics at 08/28/2018 09:52
RLM version: 12.0BL2
RLM platform: x64_w4
OS version: 6.3
ISV name: trmbldg
Hostname: ##############
User: ##########
Working directory: C:\WINDOWS\system32
Environment:
HTTP_PROXY=<not set>
RLM_CONNECT_TIMEOUT=<not set>
RLM_EXTENDED_ERROR_MESSAGES=<not set>
RLM_LICENSE=<not set>
RLM_NO_UNLIMIT=<not set>
RLM_PATH_RANDOMIZE=<not set>
RLM_PROJECT=<not set>
RLM_QUEUE=<not set>
RLM_ROAM=<not set>
RLMSTAT=<not set>
trmbldg_LICENSE=<not set>
RLM hostid list:
c63e112 disksn=X57WLXYT6 ace2d363d76c 44032c6329d8 44032c6329d7 ip=###########
License files:
C:\ProgramData\SketchUp\SketchUp 2018\EW.lic
C:\ProgramData\SketchUp\SketchUp 2018\SketchUp.lic
string: LICENSE trmbldg rlm_demo 1.0 permanent uncounted hostid=DEMO _ck=947bfccd96 sig=“60PG4580QXX0S1J6R454EDFTJABUARWFEQCBDGJ608A5UAQHYSTVPHEW64S4FYY3MVGRW09V0E60”
rlm_init() parameters:
1: C:\ProgramData\SketchUp\SketchUp 2018
2: C:/Program Files/SketchUp/SketchUp 2018/SketchUp.exe
3: <LICENSE trmbldg rlm_demo 1.0 permanent uncounted hostid=DEMO _ck=947bfccd96 sig=“60PG4580QXX0S1J6R454EDFTJABUARWFEQCBDGJ608A5UAQHYSTVPHEW64S4FYY3MVGRW09V0E60”
Local licenses which can be checked out:
Client Cached Licenses (only the highest version # shown):
<none>
In license file C:\ProgramData\SketchUp\SketchUp 2018\EW.lic
(no server)
<none>
In license file C:\ProgramData\SketchUp\SketchUp 2018\SketchUp.lic
(no server)
<none>
From embedded license: LICENSE trmbldg rlm_demo 1.0 permanent uncounted hostid=DEMO _ck=947bfccd96 sig="60PG4580QXX0S1J6R454EDFTJABUARWFEQCBDGJ608A5UAQHYSTVPHEW64S4FYY3MVGRW09V0E60"
rlm_demo v1.0 OK
Roaming Licenses:
<none>
Exe path: C:/Program Files/SketchUp/SketchUp 2018/SketchUp.exe
Version: 18.0.16975
Support dir: C:/Program Files/SketchUp/SketchUp 2018/Support
Is Make: 0
Disconnected operation
No Pro license found
Stat after trial checkout = -49
Trial checkout failed:
Demo license has expired (-49)
Overall stat = -49
Checkout failed
Eval expired: 1
Set product family = 3
Tried run as admin
Tried uninstalling, clearing all trace i can find from the registry, rebooting and re installing and coping in the activation_info.txt … same issue
Added “allow_reactivation”:“true” to the file and re run all of the above
Same issue
How can a i force sketchup to check the file or at least load the startup screen and i can enter the licence info
