Treading a path that it seems several others have done before me.
Have a laptop running Sketchup Pro 2015 and have just replaced it with a shiny new Ultra 7 but 2015 won’t activate, clicking on the activate button does nothing.
I understand there’s an issue with the activation server and that there may be a workaround.
Well after no response from Trimble I may have found a workaround.
Copied the SketchUp.lic file from the old activated PC in to C:\programdata\SketchUp\SketchUp 2015 on the new PC that wouldn’t activate, launched Sketchup and straight in with no warnings and showing all the licence info.
That shouldn’t work, but may do if you are still using a network device that you used on the old computer. If it does, that’s certainly a good way to cope with a PC that has died.
Came across this earlier post indicating that you were able to manually reactivate a customer’s SketchUp Pro 2015 perpetual license after the legacy activation servers were retired.
Currently in the same situation. Four perpetual SketchUp Pro 2015 licenses were purchased years ago and have been in continuous use. After replacing a workstation, the licenses can no longer be activated, despite being valid perpetual licenses.
A support case has been open for several months (Case #10944906), but the response has been that SketchUp 2015 is no longer supported. The issue is not a request for technical support or new features. The request is simply to continue using the perpetual licenses that were purchased.
From other posts is appears reactivation is still possible with your assistance. Would you be willing to look into whether these licenses can be restored, or point me to the appropriate person or team that can?
Also, if the process that was used in the previous case is no longer available, could you clarify what changed?
