Yes I’m working in sketchup 2014
What extension have you used for repair the drawing components which are far away
Here is the extension I used to fix the far away geometry. I’m not sure if it works in 2014:
It appears as SW Rescue My Model in the Extensions menu.
Okay thank you
FWIW I select all and explode any component and groups. I selected the visible elements then used the command Edit/ Invert Selection to pick the far away elements.
Before that I also purged unused, showed all layers and hidden geometry to see what was missing in the file.
ok thank you
