I want to export my sketchup model in .obj format. After export I can see that the mesh is corrupted.
But when export the same model in .fbx format the model is normal.
What is the problem with the .obj format?
I can also provide the model if need.
Is there any good extension .obj exporter?
can you define ‘corrupted’ as that usually implies it won’t open in any other program…
or are the faces triangulated, edges not showing…
these are both export options that can be set per format and stay set until changed…
maybe add an image of the .obj file if something else…
john
