Hi, This is my first time posting to this forum but I’ve been using Sketchup Pro since 2002. Im using version 24.0.483 on a 2020 iMac 3.8 gHz 8-core Intel i7, Radeon Pro 5700 8GB, 16 GB.
I have an issue with a Layout file that is not rendering interior elevations correctly. I used the position camera tool to create them, which has always worked flawlessly in the past, but now they are covered over with all the rest of the geometry of the building. This unfortunately doesn’t show up until I make pdf’s of the drawings. In addition, I have one drawing where I’ve created an overlay and text on a cross section but when I make the pdf the drawing is mostly obscured.
I’ve tried changing styles, flipping the images, changing the export settings, to no avail. I know I could reproduce these views by making sections of my model but I have a lot invested in the drawings already and I’d really like to understand what’s going on. Any ideas?
L’Arche_WD_BuildingD1.pdf (7.9 MB)
Take a look at the following:
Please update your forum profile. It shows you’re still using SketchUp 2018 with what would be an ancient Mac OS.
Done. Thanks for the reminder!
Update: problem solved by my clever business partner. Unclicking Output Override" in >File>Document Setup>Rendering took care of it. Thanks for your input, DaveR.
