SketchUp for iOS, 8.3.0 Release Notes
SketchUp for iOS, Version 8.3.0
This release makes working with Trimble Connect files safer and more flexible. It also brings two long-requested presentation tools from desktop and web to iPad: Styles and Fog.
Trimble Connect: Version History & File Management
You can now browse every saved version of a Trimble Connect file right inside SketchUp.
Version History: Open a file’s history to see each version’s number, date, and file size. You can open any past version to inspect it, then restore it or save it as a new file.
Copy from past versions: Copy geometry out of an older version and paste it into your current model, without restoring the old file.
Seamless saving: Changes to existing Connect files now save automatically when you return Home. Version History keeps every earlier version within reach.
File Details & Duplicate: A new File Details view shows file information. It also lets you duplicate a file, local or on Connect, into the same folder, so you can branch or back up your work in one tap.
Move to: Reorganize files across your Connect folders without leaving the app.
UK region support: You can now create and work in Trimble Connect projects hosted in the UK region.
More reliable syncing: We fixed several issues involving restores, duplicates, uploads in progress, and files deleted on Connect while they were open, so your changes are no longer lost.
Styles on iPad
The Styles panel has been redesigned with three tabs:
In Model shows the styles in your file.
Edit Style lets you adjust the current style.
Library lets you browse a built-in collection of ready-to-use styles.
When you save style changes, SketchUp now warns you if other scenes using that style will also change.
Fog on iPad
Fog settings now live in the Shadows panel. You can add atmospheric depth to your model and control where the fog begins and ends.
Other Improvements
Refreshed Home screen. File cards and list views have a cleaner design, and file menus are better organized.
Clearer 3D Warehouse placement. The Move tool now highlights automatically after an import, so it’s obvious your component still needs to be placed.
Simpler guide controls. Tape Measure and Protractor guide options have been streamlined.
Custom tag colors. Pick any color for a tag with the full color picker. The Tags panel header also got a polish pass.
Stability & Bug Fixes
Fixed several crashes, including ones related to menus, the color picker, and exploding selections.
Arc tools now handle Radius and Segment inputs correctly.
The Shadows panel now updates after you add a location.
The Tags panel now opens in View in AR mode.
The Recents list now sorts correctly.
Fixed a spacing issue in the Help panel.
The Materials panel displays correctly when the accessibility feature ‘Show Borders’ is enabled.
SketchUp for iPad: 8.3.1 Release Notes:
- Resolved an issue where collaboration may not initialize
- Updated translations: Messages are available in supported languages.
