I downloaded a dxf of an architectural drawing of a sliding window from KolbeWindows.com. It seems to import into SketchUp 2017 (and 2016). The problem is that it was drawn in inches and the model I’m trying to insert it into is in feet & inches. The model is 12x what it’s supposed to be.
The problem is if I scale it by 0.0833 (=1/12), it hangs SketchUp.UltraDoubleSlidingWindow-UltraDoubleSlidingWindow-HorizontalSection-Double4916JambDoublePane.dxf (876.4 KB)
- To reproduce, use File/Import to load the DXF file.
- Right-click and Explode the model.
- Delete the frame and then select the drawing.
- Select the Scale tool.
- Choose a corner of the selected items, then type 0.08333 as the scale factor.
