I am having a problem with sketchup… Because most of the time it freezes on startup when ik try to open a model or just a new file. i also had the same problem with sketchup 2015, thats why i upgraded to 2016. In the begining it seemed to work just fine and pretty smooth, but the next day it didnt work anymore (most of the times i try to open files) When it does open a file everything works perfect…
Yes it always seems to start, loading icons etc. but not my model… when i try to do anything it says ‘not responding’.
I already tried to reinstall it, but that didn’t work… the only thing i can think of is that there is somehow a minor bug in windows 10 or something because sketchup 2015 didnt work either.
My hardware should be able to handle sketchup easily (i7 5700hq and nvidia GTX 960M)
Navigate to User\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp. Rename the Plugins folder to something other than Plugins. AppData is normally a hidden directory so you’ll have to make it visible first.
If you are just disabling one or a few, you can disable them under Preferences>Extensions but there are some extensions that won’t show up in the list.
I have not used podium, but I will explain what Vray does, and podium might to the same thing.
As it opens regular SketchUp file, it converts all material data to Vray materials. This can take a very long time depending on the materials count and their types. It can hang forever, but it will eventually kick back.
This opening time will reduce once that process is done for that specific file.
The best advice is to disable the suspected plugin and see if it makes difference.
Window > Preferences > Extensions,
uncheck the extension that you want to disable.
Above process only if you can load sketchup. Follow what @DaveR says if you can’t open at all.
It this a Win10 upgrade?
Despite what they say, some graphic cards aren’t fully capable of working with Win 10.
I upgraded one hi spec laptop and everything sketchup went to hell. Reverted back to Win7 and all perfect again.
no windows 10 came pre installed, so should work okay. but i have to say that big models run about the same as speed (framerate) when i load them on my old crappy laptop… It seems also that it is only possible for sketchup to use about 20 % of my cpu even when it is running really slow… any tips for that while we are at it?
Mind you, SketchUp can only utilize a single core of your CPU. Many laptops also bottlenecks on heat which prevents your computer running at full speed.
Though i think frame rate has largely to do with graphics card than CPU.
Although Windows 10 came installed on your computer, the graphics driver may not be up to the job. If you can get to SketchUp’s Preferences, try turning off Hardware Acceleration under OpenGL. See if that helps. You might also check for driver updates from nVidia.
Okay, i tried to turn of the plugins, with no result. after that i tried to start sketchup with the intergrated graphicscard but it is still the same thing…
Check that sketchup is actually using the Nvidia card when you’ve set it to do so.
In the opengl settings, click the details button and see if it is showing the integrated card or the Nvidia card.
That was my main issue with Win 10, even though I had the card it wouldn’t use it.
On a laptop, the Nvidia control panel 3D settings default to Automatic graphic card selection, and in my experience this results in the Nvidia graphics sitting idle while the Intel chip tries to do all the things it cannot. 3D applications must be forced to use the 3D-capable card.
