I’ve been using Sketchup and Layout for over 10 years, though not at an advanced level. I’m having trouble with a Sketchup file when it’s inserted in Layout. Can someone help me figure out what is going wrong?
The first page in Layout is a screenshot of the model, the second page is the inserted model.
First off, the lines you are seeing in the Layout Viewport are actually in the model. They are distortions in the ground plane geometry, caused either during the import of the data from another file format or by the subsequent moving of things around while geometry is connected. If you choose View > Hidden Geometry in your sketchup model you will see that the lines are all there, but they have been hidden in the current view, either by you of by another. Hidden objects on the top level (those not contained or nested within groups or components) obey the hidden settings of each individual scene in SketchUp. In the current scene they are hidden, if you click on the only scene saved in the sketchup file called “plan view” you will see that these edges are not hidden in this scene, as the current scene with the edges has not been saved you will not be able to get back to that scene.
In Layout the viewport you have is set to show the “Plan View” scene in the SketchUp Model tab or toolbar. So that viewport is showing you that saved scene, in which the hidden edges are not hidden but are showing, That scene is also recorded in X-Ray style, which let’s you see through things, and this is the reason your colors and textures are not as saturated in the viewport.
Fixes Options:
Delete the unneeded lines in SketchUp, change the style for “plan view” scene, update. Done.
In Layout > SketchUp Model > Viewport, change plan view to “last saved SketchUp View”. Fast fix, but generally bad practice as if you ever move the model for any reason again and save the SU file the viewport will show the last saved perspective.
Better, using the current shown scene in SketchUp, make sure the camera is in PP and set to plan view then record a new scene by right clicking in the scene bar and choosing add, call it “plan view no lines”. Save your sketchup file, then in Layout go to the SketchUp Model window and choose that scene to show in the viewport.
Thank you so much, @endlessfix. I was able to record a new scene, so all is well. The remaining mystery is how the hidden lines were created. I routinely import images to use in base plan creation. This time, the image somehow became a material. Is this because I forgot to save the image to a separate tag than the model? Thanks again!
Perhaps the geometry was creating during an Intersect Faces step. Themajority of the geometry in your model is just loose, ungrouped edges and faces. It wouldn’t take much to distort your model if you tried moving something or moved it inadvertantly. You really should be using groups and components correctly. There should be no loose geometry in the model. You should also ensure you are using tags correctly. ALL edges and faces should be untagged in the model. Only groups and components should be give tags. This is the result of fixing that in your model.
