I am experiencing a few issues with Layout. It honestly feels like I’m using it for the first time because nothing seems to be working properly. The model is very simple (just a U-shaped kitchen), so I’m not sure why it’s behaving so strangely.
One of the issues is that all the SketchUp viewports in Layout display a small triangle with an exclamation mark, and I have to manually re-render each viewport for it to show the correct SketchUp scene. Previously, whenever I inserted a new scene into Layout, it would automatically display the corresponding scene from the SketchUp model.
Another issue is that the cabinet with the oven shows extra lines in Layout that are not visible in SketchUp. I’m not sure why this is happening or how to fix it.
Also, the model in Layout looks like it is using Ambient Occlusion, even though the SketchUp file is saved using the Default Style.
Do you have any idea what could be causing these issues or how I can fix them?
I haven’t checked the model but usually they are a result of using Vector or Hybrid rendering with a model that is large in extents or far from the origin. LayOut is even more picky in this sense than SketchUp.
This is indeed the best way to get rid of the triangles.
Keep in mind, though, that with large files, you might not want to do this, because it often makes your layout file unusable.
