I have sketchup pro trial 2021. I tried to import items from 3dwarehouse but no models showed after I clicked download to current sketchup model. when I try to download them from new blank sketchup page they do appear. Why is this happening and how can I fix it?
hello, you might want to look carefully at the size of your drawing. If it’s really tiny of really big, you’d probably think nothing imports from the 3d warehouse, but it’s just that it would be a very different scale and make the imported object not visible (or difficult to spot)
If you import a chair, make sure you import it in a room with decent dimensions for example.
First thing to check is the unit you are using in your model and give realistic dimensions to what you design
shift + z is a useful shortcut to the zoom extents tool. use it after importing an object in your scene if you still have troubles
Thank you for your advice.
Like you mentioned I think it’s the size. I thought my settings were in mm but it’s in meters.
Is there a way to change entire design into mm setting instead of drawing the whole thing again?
Thank you for your answer
Hello,
Select all (CTRL+a) then type “s” for scale, grab a corner, type 0,001 and hit enter
OK, maybe you could start from a new template in mm and load your model (in meters).
Wow. Thank you so much~
I think it’s finally in right size.
By the way, if I try to get close to the building certain angels look like it’s cut off when i move around.
Wonder why it’s happening. Do you by any chance know how I can fix that?
Thank you for your information.
If I have new mm template and move my model from meter, I would have to shrink them, right?
In the pro version, it’s in window > model info > units.
But it’s not going to change the model size, he would have to resize it anyway.
this is clipping, see this help page : https://help.sketchup.com/fr/sketchup/clipping-and-missing-faces
All Floors.skp (8.9 MB)
I tried to do everything I can in that clipping and missing faces help page. But, my sketcup is in different language and I think I couldn’t try it right. Can any one see what’s the problem or could anyone help fixing this clipping problem? uploading skp file and screenshot~ 3d error|690x420
All Floors.skp (3.9 MB)
you had several components very far from origin, a giant image and a slab that were hidden…
should be ok now.
You should learn the basics, as it will get messy by going on working like this.
WOW…
You are like… My hero…
Thank you so much~!!!
Illustrating what Paul told you.
The point marked is nearly 16 kilometers from the origin. Deleting that object eliminated the clipping.
I also purged unused stuff from the model. This reduced the file size by nearly 41%.
All Floors cleaned.skp (5.3 MB)
