I create a circle, and when I use the push/pull tool, the circle is split up into eighths. Anyone know how to fix this?
It might be picking up geometry from the larger circle below?
You could use the soften tool on the upper part or use shift/eraser to hide the lines without deleting them.
Have you used lines to find the center of the bottom circle?
Go to View/Hidden geometry and see if there is anything stray in the model.
I checked hidden geometry, and there were hidden vertical lines splitting the circle up… Thanks for the help.
