We’re moving our network license server and I need to create a new license file for SketchUp 8. After entering the required license information, SketchUp uses a “Browse to Folder” dialog to select the network location of the license file. Trouble is, the server is not listed. Is there a way to enter the name of the server manually?
The licensing app doesn’t give me the option to type in the server path manually. The server we want to use doesn’t have the WINS service running currently, I think that’s why I can’t see the server name.
Simply linking to your moved license file with the “Set license” command will create a server.dat file with the correct license path. If I remember right, the latter displays a standard Windows file open dialog where you can also type the full UNC path. We used to link our license via a mapped network drive, and that also works OK if the path to the drive stays the same.
SU 2015 and 2016 use an internet-based license system instead.
