Hi has anybody had problems with the new section hatch 2027 showing nicely in the model but when exported to Layout it doesn’t show, it reverts to the section fill.? I’m stumped I’ve tried a few things but can’t get it to work
The hatch lives in the style, and LayOut uses the style saved with the scene rather than whatever is currently on screen. Open that scene, make sure the hatch still shows, then update the scene so the style is stored with it. In LayOut, set the viewport to Vector or Hybrid and update the model reference. A Raster viewport usually keeps the solid section fill and drops the hatch lines.
Hi thanks for the response. I’ve used the hatch in the style saved with each scene that’s what is confusing. I’m really stumped with this one
Perhaps you could share the LayOut file so we can see what you are working with?
Thanks for coming back to me Dave. I think I’ve resolved it, for some reason it was sending the model to Layout 2026 not 2027. Ive deleted the older version and the section hatch is working.
I am having this same issue. I gave the crown molding a hatch, and made a style that displays the hatch in Sketchup. It works in Sketchup. In Layout, I toggle to the style that shows the hatch and it does not appear. What am I missing?
In Layout it’s on the last page, the crown detail.
Potts Lane Library + Hwk Rm - 11_03_26.skp (1.5 MB)
Potts Ln Library - 11_04_26.layout (3.4 MB)
For the style you made you have Override Section Fill by Style checked and the section fill is set to the dark gray shown in your model.
Inticking that box makes the hatch pattern display on the crown molding.
Updating the style, saving the change, and updating the reference in LO shows the hatch pattern there, too.
Side note: be careful with those viewports on that page especially if you add any dimensions to them.
Thanks for looking into this Dave. Yes, I have the box checked to override section fill because I figured this would be a simple way for me to have everything appear in layout as grey, and I’d have the option to change the style in layout to the one that doesn’t override section fill.
Were you able to get it so that there’s one style that shows everything as grey, and one style that shows the hatches, and that works in layout?
Also, what do you mean be careful? What are the potential hazards you’re thinking of?
Basically I want to be able to have most of the layout file appear as grey, but certain images show up with the hatches. I thought this would be the most straightforward way, but I’m sure there are other ways I don’t know about!
I edited the scene’s style to include the override and renamed it to Override Section. I reset the Style in LO to show the scene’s style.
Switching to the other style shows the hatch pattern as expected.
You’ve overridden the scene’s camera position. If you add dimensions or labels that are attached to the model you run the risk of losing them if something happens to reset the camera. For example I added some dimensions to the crown moloding.
Then I reset the Camera in the SketchUp Model panel. The entire model disappeared from view as did the dimensions.
You can’t even zoom out enough to find the dimensions. Basically, overriding the Camera properties in LO has the potential to create a lot of work for you. There’s no risk if you avoid modifying the camera position in LO and there’s no real need to do that. Here I’ve set up the viewport without modifying the camera position in LO. I just dragged the edges of the viewport to show the part of the model of interest.
The other two viewports on the page have the same potential to create more work for you, too.
So I need to have a dedicated scene with the override. Why be able to change it in layout then, if it doesn’t work? Just a rhetorical question.
Thank you for explaining all this. I change the camera position because it’s easier than increasing the scale in increments so that I can adjust the viewport in increments (since I can only zoom out so far in the layout document).
How do you recommend to adjust the viewport more quickly?
Unless there is an answer, then it’s not a rhetorical question! ![]()
Potts Ln Library - 11_04_26.layout (3.6 MB)
Potts Lane Library + Hwk Rm - 11_03_26.skp (1.6 MB)
I can’t get it to work… what am I doing wrong here?
No. I used the same scene you used. I just dragged the edges of the viewport to crop the view as needed.
It does work to move the camera in LayOut but it comes with the risk I showed you. Some users seem to be averse to setting up scenes in their SketchUp models so modifying the camera in LO works for them, at least until they have dimensions and labels go missing after an inadvertant Camera reset.
I think modifying camera properties in LO can be useful for perspective views especially for one-off documents which, once you’ve exported the PDF, you don’t care much if the camera gets reset accidentally.
I’m only pointing this out because it doesn’t seem to be covered in any of the Help documentation and because over the years there have been plenty of cases in which users have had the issue and came to the forum looking for a “bug fix” even though it’s not a bug.
I didn’t change the scale in the viewport before resizing it. I left it at 1:1.
If you don’t want to move the camera in LO and you don’t want to drag the edges of the viewport to do the cropping you can create specific scenes or you could use a clipping mask.
In my models for shop drawings I use a single scene for all of the 2D views of the parts and just drag the edges of the viewports. Except for the exploded view here, all of the viewports use a single scene from the SketchUp model and as you can see, no camera overrides (no Reset button in the Camera section).
Thanks again for explaining a little more.
My question about the “dedicated scene with the override” and “change it in layout” both refer to the style, not the camera setting.
As far as the camera, dragging the viewport seems to be the best option then. It takes longer than I think it should take, but I’ll look into clipping mask, maybe that will help. Thanks for the rec.
Any advice on why I still can’t get the style to appear in layout?
You’re welcome.
Ah … So you’re asking if you should create a scene with the style showing the hatch pattern separate from the one showing the gray fill? If so, you shouldn’t have to do that. It should be sufficient to select the style for the viewport in LO.
I have a collection of styles that I access from LayOut as needed. For example the hidden details (mortises and such) come from viewports in which the style is set to Wireframe and dashes applied to the appropriate tags. Those viewports come from the same scene as the solid line versions which are stacked on top. No dashes assigned in the SketchUp model and the no Wireframe style in the model. That’s all done in LO.
I think you’ll find it’s not that time consuming. Certainly less than the time you potentially spend fixing things if you’ve overriden the Camera position.
BTW, in that last screenshot I showed, there are 41 viewports with dimensions and labels attached to them. There’s close to a hundred dimensions on that one sheet. Can you imagine the amount of work required to fix the document if all of those happened to get the camera reset accidentally?
That’s what I would have thought. In the first set I uploaded, that’s what I was attempting.
In the second set I uploaded, I set the scene so that it had the style applied.
Neither works in layout for me, and I can’t figure out why.
You aren’t having the same issue that the OP had are you? He was working in LayOut 2026, not LayOut 2027.
I had just downloaded 2027 but actually I just checked the about layout and it’s showing “26.1.257”. I assumed I was working in 2027 but it seems I was played just the same as Paul.
Hi Nate / Dave I deleted layout 2026 because for some reason 2027 kept sending to layout 2026 instead of 2027. It works perfectly now
